cooling fans not working
pulsarmick
I have just put a new head gasket on 1.2mm steel one head been done all ok not got a thermostate in at the min my cooling fans are not working any one got any ideas i dont want to damage the engine its cost me loads now not even drove it yet :doh:
pulsarmick
there pluged in witch fuse is it i have check if the fans are working with a direct feed to the conectors where is the cooling fan switch can i use a bridge wire to check if its the switch at fault all help welcome as the cars getting on my misses nerves with having to keep spending money on it help:doh:
pulsarmick
big thanxs for the help fan are now working think the relay was stuck and blow a fuse new fuse and messed with the relay they now work big thank you for the help get there now nearly on the road :thumbsup:
well would you believe it :shock:
someones managed to solve a problem without anyone mentioning a fault code check or a compression test :lol:
glad you got it sorted, it was my good deed for the day ;)
