What the best comp ratio and Y
I've been told that for a turbo car running over 350 should be around 7:2:1
you would lose a bucket load of torque/driveability with such a low comp ratio but,you`d be able to run shed loads of boost eg 2bar+Datsun500R said:What the best comp ratio and Y
i`m giving serious thought to upping the comp ratio slightly to try and get a bit more torque lower down the rev range.
i know you thought it was fast but it only has torque over a 3-3.5k wide rev range.didn`t you notice the delay between pedal hitting carpet and light speed :lol: :lol:si.. said:you've gotta be kiddin :shock: :lol:
sounds like you need to get yourself a more efficient turbooap-r said:didn`t you notice the delay between pedal hitting carpet and light speed :lol: :lol:
yeah i noticed it, but the intensity of when it did kick in more than made up for it. :twisted:i know you thought it was fast but it only has torque over a 3-3.5k wide rev range.didn`t you notice the delay between pedal hitting carpet and light speed
may i suggest you fcuk off :lol: :lol: :lol:Edd said:sounds like you need to get yourself a more efficient turbo![]()
may i suggest an HKS GT3037S or GT3240![]()
just 87mm forgies from hks but it has a 2mm head gasket which might be a touch too much.si.. said:so are you running the pistons that came with the 2.2, what comp are they?
as 1 of the mods keeps banging on about,yawn,torque is everything :twisted:Edd said:Well we will see Sir oap-r, we know who's car has the most proven power so far![]()
i hope your going to get it mapped for a bit more boost :twisted: :twisted: to suit your nice new clutch:twisted:
i was thinking more of a 1.5-1.6mm head gasket and hopefully still keep 2.0bar on optimax with a seperate map for when using the race fuel.skiddusmarkus said:Two of 'em now Bruce.I've gone for 1mm HG so compression will be about 8.77:1.I'll be running Link ECU and water injection for high boost(hopefully 1.6-1.8bar) though.Should see me with loads of low down torque and a far whack across the revrange.If that's not enough then there's always the nitrous
.And no,it isn't cheating
As opposed to a seperate map for race fuel which isn't used on the road for normal driving either.Nitrous is a race fuel too IMOwas thinking more of a 1.5-1.6mm head gasket and hopefully still keep 2.0bar on optimax with a seperate map for when using the race fuel.
what happened to "back on topic"skiddusmarkus said:As opposed to a seperate map for race fuel which isn't used on the road for normal driving either.Nitrous is a race fuel too IMO.
most people,like i intend to,would just add the race fuel for special occasions like the pod,totb etc.i would try and use most of the tank on the way down and just add the race fuel at the venue.probably wouldn`t make any difference if you had a few litres (4-6) of optimax and 20-25litres of race fuel.you could then just top up with race fuel as the day goes on.you would also need to have a seperate map for the race fuel that you could d/load into the ecu or you wouldn`t get the benefit of it,except as a safety margin.skiddusmarkus said:How do you make run the car just on race fuel without having 2 seperate tanks?There's always going to be some Optimax in the tank unless you syphon it all off.
