brake pressure
Marci GTi-R
Hi guys,
My brake pressure seems a bit low. Is there any way I can adjust the pressure?
I have a 6 piston big brake kit at the front with bigger discs and a tarox big disc kit at the rear. It seems like rear right is not braking right.
Regards Ramon
Well this could be related to your other thread about vacuum problems. - No vacuum means no assist.
Having said that, maybe you need a bigger master cylinder to get the fluid to all those pistons.
Check the rear right hasn't seized.
You could try bleeding them to see if there's any air trapped?
Do you have the standard rubber hoses still? Might be worth changing them.
