My thoughts exactly, but I did a compression test last August with OK results.There may be a simple explanation, the finer points of the breather system are lost on me, but I'd consider doing a cylinder compression test.
How/where did you test it?I pressure tested the piping from the turbo all the to the intake, to check for boost leaks. At approximately 1,5 bar i heard that the pressure came up through the engine oil filler cap.
Is this normal?
This is how I did it:How/where did you test it?
Obviously the pipework before the turbo (but after the AFM) is connected to the rocker cover, so if you pressurise that it will get to the oil filler.
If you have the PCV fitted still (that little valve near the filler cap), I suppose there's a possibility that it's letting air back past it and in to the rocker cover. - I thought that was after the throttle bodies, so they'd need to be leaking (although that's not unlikely) in addition to the PCV not functioning (since it's supposed to pull the crank case emissions out under manifold vacuum).
I'm not a mechanic, but if air was leaking past the valves wouldn't that mean you have no compression?
Sorry, I misread his post :doh:I think Pobody meant how did you do the boost leak test. If you pressurised from the air intake on a standard set up you may be pressuring the rocker cover, crankcase and breather system, the only way out would be through the oil filler. If pressurising post turbo it may indicate a obstructed breather system. Bad news as you may see unacceptable crank case pressure when driving,
I'll have a look at the PCV tomorrow, thanks^ Yes, that's what I meant.
I'd guess the simple answer is that the PCV is knackered.
Positive Crankcase Ventilation. - It's essentially a one-way valve that's supposed to allow crankcase vapour to be pulled through the throttle bodies under vacuum (and prevent pressurising of the crankcase under boost).Display excessive ignorancewhat is a pcv?
You are right, I first noticed it by seeing small bubbles around the oil filler cap because there was a little bit of water around there. Then I opened the oil filler cap and I could hear the air coming out the oil filler hole.Ok. Thanks Pobody, so what happens to blow by gases when the engines not running on vacuum? Out through the breather system and recirculated through the boost charge to gunge up the intercooler and plenum etc? Guess that's why a catch can is a good idea, along with the fact that blow by has lower oxygen content- probably a bit warm as well.
I would have thought that the biggest issue with a stuffed PCV valve is that some metered air get dumped to atmosphere/ intake, through the breather, and you run a bit rich. Easy solution, if you're that fussed about having a bit of extra fuel available when jamming 1.5 bar down your engines neck- plug it up. Saves all that gunge getting into the throttles and IAC valve as well. Does anyone plug the PCV check valve?
You're probably correct that what OleH is hearing is air bleeding through the PCV check valve, but that's not what he seems to be saying. He seems to be saying that he can hear air forcing out around his oil filler cap. If that is the case he's pressurised his rocker cover and, presumably his crank case, which would indicate that his breather system is not open to atmosphere. That could be a serious problem when he starts driving it- cue blown oil seals.
While we're on it what's a leak down test, why do you do one at TDC, why are valve stem seals designed to leak, and, hopefully, where does the leaking air on a leak down test go?
I'm no mechanic either.
You do it at TDC on the compression stroke so that both inlet and exhaust valves are closed then in theory the cylinder will pressurise if it's not leaking too much. The leaking air goes where ever the leak is. ie Out the inlet, out the exhaust, into the cooling system or into the crankcase.While we're on it what's a leak down test, why do you do one at TDC, why are valve stem seals designed to leak, and, hopefully, where does the leaking air on a leak down test go?
I'm new to this site, so hi! My background is BMW master techSorry, I misread his post :doh:
This is how I check for vacuum leaks:
1. Remove the air filter pipe from the inlet on the turbo
2. Insert a plug with a tire valve, in to the turbo inlet
3. Pressurise the system with an air compressor
4. Listen for leaks
Hope this made any sense ;-)
No issues really, engine is running OK, but when I pressurised the system the air is coming up the hole for filling oil on the engine. I'm just wondering if this is normal :?I'm new to this site, so hi! My background is BMW master tech
and I have my own garage and I'm an Aussie
m
can I ask what the problem was for you to do the vacuum leak test?
I would be more inclined to do a smoke test for that?
