Bolts torque on the turbocharger!
RO_SUNNY
Hello guys.
I have a small question .
What torque should I apply when tightening the bolts from the hot side of the turbo after ''clocking'' it?
My case is an GT 3071 r (with ball bearings)
Your answers will be highly appreciated!
Cheers,
B
Geo3
I did same with mine mate just use common sense I think not wrenched up but obviously not loose. Use common sense mate unless someone can give you specifics
Didn't you read the other thread you posted this question in? Steve had already posted the answer.
The turbine (hot side) is 185-215 in-lbs.
Is something getting lost in the translation?
You've cracked the nuts on the turbine side so that you can rotate the housing?
Now you want to do it back-up, and don't want to over-tighten the nuts?
- According to Steve you want a torque of 185-215 in-lbs (or 15-18 ft-lbs or 20-24 Nm)
- If your torque wrench is like mine, that's probably the lowest setting on it.
You can't get the socket on the nut/bolt (then how did you undo it)?
You can't get the wrench to clear the turbo etc (then why not fit an extension to the socket)?
RO_SUNNY
I learned my english ....so it might be something lost in the translation.
I didn't used a socket wrench to undo the bolts....I used a spanner.
Any way thanks for the help!
Cheers,
B
Yeah, I appreciate that English isn't your first language, and that you do a lot better in it than I could ever do in Romanian. That's why I just wanted to make sure we understood the problem.
