Apexi Avc-r wiring
E
Evil_GtiR
Would someone be kind enough to post a wiring guide for apexi avc-r specially for the Gtir into the "How to Guides" section? Thanks so much
If ur lucky either rsnissan or ex-gtir will see this post and do one for you.
Curtis
The wiring with that guide from the Apexi site is a piece of cake.
The hard part was trying to find a place to get the plugs through the bulk head! :wink:
E
Evil_GtiR
thanks guys, by the way, after setting up the injectors, no. of cyclinders,etc... do I still have to do the road tune (I heard it needs tuning to your car?)? If so, how do i do a road tune?
Curtis
Once you've put in a rough duty setting across the rev range and put it onto self learn, you need to find a clear long piece of straight road for you to do a few full throttle foot to the floor right through the rev range blasts! The Apexi will then learn your car and adjust the duty to hold the set boost all the way through the revs. Depending on what you entered as your start duty it may over boost a bit until it adjusts.
If you read the online manual on the Apexi site it does tell you all this.
Obviously the queens highway is not ideal for this set up phase, but may be all you have to use... :wink:
