Quite a lot of us use the Micra battery but don't know anything about the cranking amp...donpulsar said:Anyone running a Micra battery :?: If you are, could you tell me what cranking amps it's rated at ? Cheers![]()
Yes that was the same problem that I was having but it got even worse when I fitted my TV/DVD/PS2 so I bought a bigger battery which cranks at 380ish but will not fit properly into the battery tray but seen as I plan on re-locating it to the boot it will not be a problem for too longGinga
Yeh its crap cranking amps is about 270ish iirc
I find its ok aslong as cars used everyday but if only used at weekends etc it quickly goes flat
