dump valves and blow off valves
japedup
wats the difference between the 2 and which makes are the best,also which would you recomend :?
T
T11EWL
There are two types though -
Atmospheric dumpvalves or BOVs are the ones that make the whoosh noise - alegedly cause fuelling problems but no-one on here has had any problems
Re-circulating valves 'dump' the air back into the intake so the same amount of air the MAF detected coming into the intake is circulating round the system.
MAF - Mass Air Flow (sensor) - tells the ECU how much fuel to supply to the engine
Some clever f*ckers have made them that re-circulate at low pressure and dump to atmosphere at higher pressures.
So that would make 3 types :)
