3037/manifold decision time
Do i f*ck off that piece of sh*te HKS s14 manifold?
  • keep it, s14 stuff on an R rocks
    Votes: 0 0.0%
  • Total voters
    77
E
Edd
Here are some pics...
Now my choices are limited, as i can't really move the rad much further forward as i have the intercooler with two fans inbetween that and the rad :cry:
Think i may stick with a std manifold and get it reworked and wastegate added :oops:
E
Edd
one option is to fit a standard rad which is a lot thinner than the rad i have now
another option is to reweld the flange on the manifold to angle it away from the rad and more towards the block
a further option is to wrap the turbo up in a blanket :wink: to help protect the rad
cmng
Have anyone tried to use HKS SPL Kit for S14 and S15 fitted on GTIR ?
i might have mine fitted in 2 month time
E
Edd
Thats just the angle the 3037 came with Steve, just have to loosen the compressor housing bolts and rotate it to whereever i want it to face when i decide the pipe run :wink:
stevepudney
GTiROC CHAIRMAN
Well, the way I see it is you can go back to the standard manifold which could be a slight power restriction or what I would do is cut the flange off and reweld it back on at a better angle. I would also wrap the turbine housing and mainfold in heat wrap to keep under bonnet temps down and protect the rad.
E
Edd
Yes cutting and rewleding the flange was one of my favourite options if i keep the manifold, standard's always an option.
I think i can probably move the rad forward a little bit more, maybe up to an inch i will check clearances later.
Heat wrapping the turbo and manifold i think will be only option
then just watch the rads pop lol
stevepudney
GTiROC CHAIRMAN
Take a look through the Demon Tweeks Motorsport catalogue, there loads of heat shiel options in there
E
Edd
yeh i know, it's a shame i cant heat shiled the rad but wouldnt work due to airflow and position of fans :cry:
GINGA
the best and cheapest option will probably be the have the hks manifold modified to change the angle of the turbo :wink:
antilag
lend me the turbo and manifold to run my car in :D and u pay for me to custom all the pipes then u get back a kit that fits and everyones happy :D :D :D apart form the glouster boys as u still cant marry your sister there
u no who u all arrrrrrrrrrr
