GTiROC > Technical > Problem Solving
Portal Forums Gallery Owner Map Arcade Grafitti Wall Links
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
Old 08-02-2010, 11:45   #1
icecool70
1st Gear
icecool70 is an unknown quantity at this point with no rating
My cusco catch can
Had this fitted for a year now and so far not had to empty it once. i check it at least once a month but over the last couple of weeks noticed it started to fill up to the point now.. well this morning that its full to the brim. does this mean i have a problem? the car still starts and runs fine
icecool70 is offline   Reply With Quote
Old 08-02-2010, 12:32   #2
si...
Idling
si... is an unknown quantity at this point with no rating
i would get it emptied mate got one myself but not had it on long so cant really say
dont they have a drain plug?
si... is offline   Reply With Quote
Old 08-02-2010, 19:57   #3
icecool70
1st Gear
I will do but just a bit worried why it filled up so quick
Old 08-02-2010, 20:32   #4
Official GTiROC Sponsor
pulsarboby's Avatar
pulsarboby is an unknown quantity at this point with no rating
check your compressions as you may have a worn piston or pistons.
youll get ring blowby which will pressurise system and cause oil to fill the can.
also check that the pcv valve is working all ok as this 'if blocked' will cause pressure through back part of breather system
__________________
www.GTI-R-us.co.uk for all work, engine builds, cars for sale and quality spares
pulsarboby is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
