GTiROC > Technical > Problem Solving
Portal Forums Gallery Owner Map Arcade Grafitti Wall Links
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Display Modes
Old 18-01-2009, 12:44   #1
Sween
1st Gear
Sween is an unknown quantity at this point with no rating
Short ratio gearbox
Ok guys so it is another gearbox question. I have a local contact who has a number of Pulsar gearbox's for sale and he at least one of them is a short ratio gearbox from the rally version. Considering that we are all aware of the known issues with the normal gearbox I wondered if anyone knew of any issues with these boxes?
Sween is offline   Reply With Quote
Old 18-01-2009, 12:53   #2
Gav_Kara
2nd Gear
Gav_Kara's Avatar
Gav_Kara is an unknown quantity at this point with no rating
im running one mate u loose top end speed but compensate with it faster through gears so makes ya car a good 0-60 beast
Gav_Kara is offline   Reply With Quote
Old 18-01-2009, 13:36   #3
5th Gear
PobodY's Avatar
PobodY is an unknown quantity at this point with no rating
Quote:
Seconded - you just run out of gears. Not a huge problem on the roads because you're not supposed to be going fast enough to get to that point. You also don't need to build the boost quite as much if you need to get a quick start, but you need to be ready to shift pretty quickly too.
It'll get you to over 100mph, more than that I can't really say.
PobodY is offline   Reply With Quote
Old 18-01-2009, 13:39   #4
Sween
1st Gear
Cheers for your help guys. What about launches and the box disintegrating. Is it a sturdy unit?
Old 18-01-2009, 14:24   #5
Gav_Kara
2nd Gear
Gav_Kara's Avatar
Quote:
not shore about launches mate never done it in mine!!! ive had mine almost two years now and seems ok!!! all depends how you treat a box and clutch if your launching it ect it will only last like a normal box and limited time!!!
Old 18-01-2009, 14:17   #6
5th Gear
PobodY's Avatar
I haven't had mine long enough to destroy the box, but I don't know that it's any better.
I know the synchro seems to have gone on mine on 5th gear and I need to double clutch if I don't quite get the revs right. It's also possible that it was rebuilt before I had it.
Old 18-01-2009, 15:47   #7
whippet trainer
Fast Guy's Avatar
Fast Guy will become famous soon with 2 out of 10Fast Guy will become famous soon with 2 out of 10Fast Guy will become famous soon with 2 out of 10
I've had mine long enough and haven't killed it yet, bear in mind I only have about 290bhp, but I'm not shy about lanving it.
Fast Guy is offline   Reply With Quote
Old 18-01-2009, 15:57   #8
Official GTiROC Sponsor
pulsarboby's Avatar
pulsarboby is an unknown quantity at this point with no rating
because of the fact that the gears are a shorter ratio technically you should not break them as easy under launching i would have thought, as you need to shift from 1st almost immediately (second is like 1st on a standard car)
so there should be less strain on takeoff.
downside is that you need to be able to shift gear very quickly to get to 60-80 and that means you run the risk of crunching the gears through being aggressive with gearchange
__________________
www.GTI-R-us.co.uk for all work, engine builds, cars for sale and quality spares
pulsarboby is offline   Reply With Quote
Old 18-01-2009, 16:45   #9
whippet trainer
Fast Guy's Avatar
According to the gear ratios I've found, c/r 1st is longer than standard 1st
1st ----- 3.285-------RB: 3.067
2nd ----- 1.850------RB: 2.095
3rd ----- 1.272-------RB: 1.653
4th ----- 0.954-------RB: 1.272
5th ----- 0.740-------RB: 0.911
Reverse - 3.266 -----RB: 3.153
Old 18-01-2009, 17:01   #10
pulsarboby's Avatar
i find that hard to believe tbh even though its in black n white
you have to admitt karl that first is pretty useless as you have to change so quick! when i drove the rb that ive got the difference to a standard box is incredible, to the point of its not like driving the same car, on many occasions ive skipped first and just use second to pull away, unless the one i have is totally different.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
